Noise from passenger side in Idle
fadyasha
1,134
Hey guys,
so those following my posts probably know that I had a long day doing some mods and repair. During check up I came across this noise from the passenger side. You can't hear it when your standing at the front end and hood open, but you can clearly hear it when you're standing right next to the front right wheel. At first thought is from the AC but turned it off and had no affect on the noise at all.
ps: I'll try to post a video in the morning, it was too dark outside so all I got is a audio clip. Had to trim it a bit because of size limitation but it pretty much sums up the sound
xtremeskier97
28
I'd be better if there was video with it so we can see what you see and what you're moving past as the sound changes.
fadyasha
1,134
I'll get to that in the morning hopefully, but there isn't much to show. Not much can be seen from the passenger side anyways. I'll see if I can get some decent up
CaptainXL
fadyasha said:
Hey guys,
The only thing that can rattle like that in that area is the heat shield:.
fadyasha
1,134
False alarm guys. Turned out to be the right strut. I already having problems there cuz of the new lift install. Hopefully today I'll get that sorted out and issue solved :tongue:
jagman
