- Apr 26, 2012
- 404
The front A/C works great. The rear A/C did have a bad actuator (blend door). Verified that it was bad visually (would not respond to commands nor recalibrate) and with a scan tool. Removed bad actuator. Was able to move the blend door with my fingers (it springs back when released), could hear it open and close. Installed new actuator. Visually watched it respond to commands.
Rear A/C however is not cold. It is warm. Verified by sitting back and using rear control. Air does not get cold even though the blend door is controlled by the actuator.
What could be causing this? If it were leaking, why would I have A/C in the front? I have been using the front A/C all year.
