- Jun 22, 2014
- 1,576
Yeah all of your suggestions probably should work but, there's a a big but in here
I also want my perifier (spelling) lightning to work when I hit my RKE as designed, with my diagram it should work on the fog lights. And the DRL turned off when put in park.
And the fog will work on the switch as it was intended to do because I just splice in on the fog lamp wire, see first post with pics.
EDIT: Attached is a pic of a stock OEM relay, low beam HL and cooling fan uses the same kind of relay 15016745. Notice the complexity of the internal on the relay, this is not a standard relay. Looks like it have a PWM converter built in the relay.
