No AWD or 4HI
Jonbussie
10
When I try to switch to AWD or 4HI I hear the axle actuator motor working and lights on the switch show that mode has change to desire setting but the front tires are not engaging. I tested it tonight on a snowy uphill driveway. No four wheel drive. Any ideas?
14,955
When was the last time that you know that it worked? It could possibly be your TCCM. I hope that you have kept up on the transfer fluid changes at 50K intervals.
4,030
:iagree: Being an 02, I'd suspect the TCCM.
Almost certainly a mechanical failure in the front axle disconnect. TCCM failures have different behavior of the mode switch and "service 4wd" lights.
Jonbussie
10
Hey roadie. How would I go about diagnosing the mechanical failure in the front axle disconnect?
Jonbussie
10
I know it worked last winter. The service 4wd drive light briefly came on when I tried to switch to 4wd. I pulled over, shut the vehicle off. When I turned it back on the service light was off
Jonbussie
10
I replaced the transfer case last year. A new differential was installed 2 years ago
14,955
You can get either one, there is no preferred one that I know of. It is just being able to get your hands on one.
Jonbussie
10
I've changed the differential seal on the drivers side before but the not differential bearing. Is this a difficult task if the bearing is indeed bad?
y33tsteve
