Need some good quick Repair advice
jeffro312
East Haven,Ct
hi i own a 2004 buick rainier i have previously posted some issues ive had on here.
so recently my car got hit while parked in a parking lot
getting to be 3k in damage.
this 3k of damage doesnt look all that bad so i may use atleast 1k of it to repair some of my issues.
anyone have an idea of cost for a shop to repair rear air bags car sags after sitting one night..
also no awd a different shop said that the code he researched showed a bad wire harness on a speed sensor does this make since? the harness cost like 40 dollars i think but does a harness just go bad over night then just have absolutly no awd what so ever.... i go in mud spin tires and only both rears arre spitting mud fronts never grab... but while truck is in the air the front tires will spin also only get a awd code when spinning tires for like 30seconds wich quickly goes away after shutdown and start truck... this sound like a bad harness to a speed sensor??
i also have a really rought idle misfires all over counted 40 in a 15 minute drive using torque app and a bluetooth adapter not sure how accurate it is. but that is more involved i think so ill have them run compression test and vacuum test i think see what they find....................
if vacuum is bad what does that mean.. like what does that point too
if compression is bad what possibilites cause that
do you think 1k will cover all this ??
thanks for any info you guys are of coarse the best and are why im keeping my buick
1000 apologies if I don't recall off the top of my head, but how many miles?
If you're not doing it yourself, we're not the right people to ask. You can slap in OEM or Arnott replacement coil springs for $200. Z71 Tahoe/Avalanche springs for $50-75. If you're paying a shop, you need to ask the shop. Arnott replacement bags will cost as much as you can find them for on Ebay or the web.
Sure. A bad hub speed sensor will confuse the TCCM and you'll never get engagement. A GM Tech II or equivalent high end scan tool will tell you (or the mechanic) for sure.
Sure, especially if you're in an accident.
Normal if the TCCM isn't commanding transfer case engagement. Or the transfer case is toast because the fluid wasn't changed religiously every 50K. (Was it?) Or the encoder motor is bad. Again, don't have us GUESS - get an honest and competent mechanic to make a real diagnosis.
Residual friction in the transfer case clutches.
Any guess we made would be worth what you paid for it. Locate a mechanic.
Isn't that causing you to have a SES light and a code? If you're over 100K miles, did you change plugs?
Good idea.
A leak. Could be in a dozen places. An experienced mechanic can search for the typical ones.
Any of another dozen things that have been discussed dozens of times in threads with the word "compression" in them. Some of them are very expensive to fix, if the head has to come off.
ha thanks for response roadie
i have 175k miles
id like to keep bags and im having shop do it only as they are doing me a favor thanks
if a bad speed sensor is confusing the tccm then the tccm will not command the transfer case to put power to the front correct?. im going to assume its safe to say that if there was a bigger problem ie. tccm is dead or encoder is dead or transfer case is fried then i would have a constant awd dummy light on
instead light comes on when it cannot read this speed sensor
about the misfires... i do not get a code nor even a pending code. the scanner log records misfires on cylinders they are random and i guess dont miss enough to set a code. plugs were changed 10k ago i inspected them all looks to be ok. when truck gets hot after a long long drive the vibration seems to settle
mechanics i go to and trust do not have a tech 2 and the stealership is only place that has one and not so sure if after they run a test i ask them to ill get a honest answer of actual issues these guys from expierience like to make money so they misinform customers of actual problems to get more cash if they get away with it. so if i ask them if its a speed sensor they will come back and tell me that its something else triple the cost and ill never know because if i have them fix it they will fix the speed sensor for 40 bux and charge me for a transfer case get what im saying unless i travel furthur and try the next dealer its just how my local one works
thanks for your pointers as usual helpfull
love the magic 8ball btw
Well the shop found a major vacuum leak so there replacing the intake gaskets see how that goes
As for awd he tells me after he reset something awd has been working so well see how long that lasts
Ecidemon
