Just to recap what has been looked at so far… as an Itemized List:
(1) Fuel Pump
(2) Fuel Pump Regulator
(3) Damaged Fuel Line
(4) Fuel Filter
(5) Fuses
(6) CPAS (Camshaft Position Actuator Solenoid ...Replaced with OEM New One?
The symptoms of the Misfires (which should code out as either P0300 for Random Misfires or P0301-0306 for each specific Cylinder Misfiring would make it a good idea to examine the
Spark Plugs for them all looking Bone Dry...and a showing a nice, crispy “Fried Chicken Brown” color to prove that the Spark Plugs are igniting a nice Fuel-Air Mixture. If you decide to eventually replace them… Do not Gap them… they come from the factory pre-gapped so their Electrode ends ...coated with a thin layer of Rare Platinum ...will not get chipped or flake off.
Prior to removing the Spark Plugs… Remove each of the Six COP (Coil On Plugs) and use some “Canned Air” used for blowing out computer keyboards, etc… to blow out each Spark Plug Well of any Dirt, Debris or Motor Oil that may have leaked down around each Spark Plug. This will prevent any of that mess from dropping inside of the Cylinders as soon as the Plugs are removed.
Observe the ends of the Spark Plugs well… and look for a Black, Sooty appearance and whether or not they are still Wet with Gasoline. If it was not an Oversight in mentioning that the Plugs have already been changed… replace them with only the ones recommended for this odd engine: ACDelco ...and then swap around a few of the COP (Coil On Plugs) and check the Ignition Harness carefully for any damage where the Connectors plug into the Main Harness. Try and start the engine to see if any of these changes has had the right effect.
If those “Wet Cylinders” are present throughout each and every cylinder… Check that the PCM three Harness Connectors are properly attached to the PCM… and if not… remove all three and get some CRC Electrical Spray from Autozone (NOT WD-40 or Brake Cleaner)...and allow them to thoroughly dry prior to re-attaching the Three Harness Connectors. Another cause of “Wet Cylinders” happens under conditions of Very Low Compression… so low as to preclude complete combustion. Harbor Freight sells an inexpensive Compression Test kit that will do the trick in figuring this out...as both Wet and Dry Compression Tests.
Seek out the Youtube Channel of one of our respected Senior Members known as “MAY03LT” and search through all of his Trailblazer 4.2L Diagnostic and Repair Videos for "Cranks, No Start" Videos. I must warn you that he laces his dialogues with a great deal of Strong Profanity...so watch his videos when the Kids are not nearby. Nonetheless… his guidance and knowledge about solving the problems you are dealing with here are quite sterling and educational.
Use the Search Feature suggested by
@Mooseman in the available FAQ here at GMT Nation and it will speed your access to these related topic links to a lot of other Threads that have a great deal more information as well.
