Hmmmm
CaptainXL said:
It was something I noticed once. I can't remember where I saw it using Torque. I will try to find it again.
My point was if you are still choosing to investigate power production type issues, I assumed you would have some reason for distrusting or disregarding the the reported result. I was hoping your reply would offer that feedback on your thinking there. Otherwise, and perhaps C-ya has a valid point, the 267hp seems like it's at least pretty close to expectation, and should send you looking in other directions...your thoughts? I don't have Torque, so I can't comment on how accurate the calculated result is.
CaptainXL said:
I just look at my tach and can feel the boost the VVT gives me. I used to notice the boost around 3K but now it's later around 5K.
I'm still unclear whether we are talking about the same thing. It adds to the (my?) confusion a bit when there are 2 similar acronyms. The Cam Angle Sensor (that you already changed) is (my understanding only, someone correct me if I'm wrong) involved with the PCM being able to command the correct ignition timing, in conjunction with the Crank Angle Sensor. This allows for the limp home mode in the event that one of the two sensors goes bad.
OTOH the Camshaft Position Actuator Solenoid, is what the PCM uses via engine oil pressure to effect the Variable Valve Timing. From the Vortec 4200 technical paper I downloaded elswhere on GMT (Mooseman maybe?) VVT is intended for "...linear delivery of torque, with near-peak levels over a broad rpm range..." (from page 10 of that doc): {Aside @ gmcman...given the 25 degree range that the PCM can adjust the exhaust cam timing, I suspect it must not be on/off, but rather progressive depending on conditions}
So to me that sort of fits my experience with my truck...no noticeable "boost" at least not in the way I understand you to mean it. I DO however get a "flat spot" where there seems to be a slight/brief lag lasting for about a second from ~2300-2400 rpm, after which the pickup seems to increase...this may be the "boost" you are referring to. I did a plot of some of the data from my scan tool run which shows this a bit better:
CaptainXL said:
gmcman said:
Here's a great demonstration of the lag in throttle opening when the gas pedal is depressed....May explain the surge at 3K a little more.
I've always been at WOT with all my tests when i feel it kick in. This demonstration of the throttle does not relate to my tests because the throttle would be fully open after at most three seconds as seen in the video. It's interesting but unrelated.
Furthermore, since I have a stock PCM, CaptainXL and I have the almost identical vehicles, and mine does NOT seem to exhibit the throttle lag behavior, I don't think that video has much bearing on his problem comparatively speaking.
Cap'n, you never did say if you want me to collect a bunch more logged data for you to compare with?
