Kooks has it in the same spot:This is it has the O2 sensor only getting the exhaust stream from the front 3 cylinders. Are the kooks that way also?
Seems like a bad idea to leave half the cylinders totally out of the reading.
Even with washing my engine bay I have yet to experience a cracked manifold... I should stop now lol but I could understand if it were a regular issue.A former (banned) member here recently put Kooks headers on his truck he got for a great deal. Was tired of cracking his manifolds, he's pretty hard on his truck doing highway runs weekly. He hasn't told me about any issues as far as o2 readings.
Woah. Obx copied them? For anything from china it should be cheaper than $500 but I am sure you can get them to go lower. It being a good deal, I feel you would get better gains from Limes turbo up pipe. I am not denying the flow or long tubed header gains, but its $500 for something that may or may not work. If your mani is cracked. SURE. I doubt the O2 sensor being in that location has any negative impact. If something is wrong where the O2 needs to make a change, the damage would be done by then over time. Most chinese crap I buy that has to do with exhaust systems usually get made and sole to you from $21-$55. Something like this, should only cost the consumer a few hundred. They are gouging only slightly...
Doing a lot of runs at high speeds and RPM's on the highway will crack it. That's why he went through two, he does this all the time...Even with washing my engine bay I have yet to experience a cracked manifold... I should stop now lol but I could understand if it were a regular issue.
