cmatb08 said:so im thinking about a few things let me know what you guys think?
cmatb08 said:long tube header
cmatb08 said:e-fans
I would do the DIY setupcmatb08 said:a custom ground cam
cmatb08 said:and a new tune?
PCM4lessthe roadie said:Then efans, then SS wheels and tires, then bumper. For yours in trade and $4000, you could have an SS.
Wooluf1952 said:I've never seen a dealer offering long or short tube headers for an I6.
From a post last October on the SS site, I think you might be right:Pittdawg said:Or a tune. I call b.s.
cmatb08 said:i would love to get a ss but the insurance on one for me (under 25) is ungodly (4-500 a month) and that is too much to spend on top of the monthly payment, gas, and two kids!
cmatb08 said:thats what im thinking minus the turbo i would like to keep it N/A just pull a lil more power out of the i6 i have a remanned motor/ custom (if that makes sence) it was cleaned up (10 over) and then i had it punched another 10 so if i can port and polish the heads do a real mild cam and a custom set of long tube header re tune it and throw a set of 3.73s in the rear that should give us a little bit of a boost when we need it! our gas mileage is sucking right now because our fuel pump is goin out but that will be fixed this friday then ill be replacing the fuel filter, cleaning the air filter, throttle body, and throttle body spacer. has anyone ever p&p the throttle body? i know when my wife had her mustang that was a big thing that they were doing to the v6s.
fletch09 said:found this w/ search.
http://gmtnation.com/f25/my-hannukah-gift-myself-arrived-christmas-eve-936/index2.html
remembered it being discussed
cmatb08 said:do you still have the p&p throttle body? did the idle ever fix itself?
limequat said:The ballessness before 3000 is probably more torque management than anything else. Get a tune and it'll feel much torquier. Cams aren't available unless you weld the stockers. Head porting shows proven gains. Header will have to be custom, but you could get your stock manifold ported. The 4200 chief engineer said that there's 30 hp tied up in the exhaust system.
McGMT said:Yes, the "ballessness" off the line is from torque management... But then between taking off and 3000 the engine doesn't produce very much HP at lower RPM's.
Torque is beefy though and the curve is pretty good (constant) all the way thru the RPM range peaking around 3600.
HP doesn't peak till clear out at 6000... Depending on the year you have between 270 and 291 HP and 275-277
cmatb08 said:It's a 2004
McGMT said:A 2004 would be on the lower end, 2006 they squeezed out the most then after that it hovered around the top end..
