Max tongue weight 400 Lbs on my Envoy. Is it the frame/hitch strength or the rear suspension that limits this?
c good
533
I want to add a motorcycle carrier or a cargo carrier between the receiver hitch and my small trailer. (14 ft, 2900 gvw, 230 lb tongue weight) The motorcycle weight is 275 lbs. When I'm not taking the bike, I would like a little extra space for a 50 lb generator or some firewood, cooler etc.
My question is. As above. Is it the frame and hitch that limits the weight or the rear suspension? If it's just the suspension, could I add some airbags to make up for it? Thanks for any info.
littleblazer
9,265
It's the springs. The receiver itself I recall was stickered for 750lbs. I thought the tongue weight was in the 600lb range. I used to use a hitch haul loaded up woth 4-500 lbs of junk and with the air bags it worked fine. It does impact how the car handles, lot less weight on the nose.
cornchip
637
Don't forget to inspect the rear steel portion for severe rust if your in a road salt area. These bumpers tend to get thin with age.
Matt
4,025
He's in the part of Cali that's the land of blondes and sunshine.
moscoreli
