MAP Sensor P0106
rgoldberg
35
04, 4.2L...New Magnaflow Cat...cleaned throttle body when I replaced the CAT...
Getting an intermittent P0106, it doesnt light up the Check Engine Light, i know because it kills cruise control and I watched it yesterday on Torque where the MAP pressure completely rest while i was driving and simultaneously killed the cruise control.
I verified that with the ignition on and engine not running the sensor shows 100kpa(~15psi) at 5-4.8v which is correct, but at idle (660rpm) it reads 36kpa (5psi) at 1.37v when it should be 12kpa (1.7psi). If I short the 5v to the signal it reads 104kpa (15.08psi) which is correct.
I've done wiggle test of the harness...i've check grounds...not sure the next step...
also I made these readings with 2 sensors! I will say the a/c delco I got from amazon looks used...
any help would be greatly appreciated.
Did you check actual vacuum? Might have a leak. If you're getting the same results using both MAP sensors, I'd rule that out.
Reactions: Tiggerr
rgoldberg
35
What if I told you that I'm simply a idiot?
I couldn't find a vacuum leak, and all my wiring check out, so I pulled the TB on Saturday to inspect it.
Seems after cleaning this thing probably a couple dozen times in the past 8 years that the last time I cleaned it, 2 weeks ago, I decided I'd loosen the butterfly valve so I could get the TB cleaner!!! Well I didn't quite put the butterfly valve back in the right spot and it was getting stuck.
I reset it properly, made sure it moved freely, and no more P0106 MAP code.
Lesson learned.
Mynamesjeff
