Sorry that this took so long to dope out... but below is a Complete Pin-Out List for All Three BCM Connectors
(...with a prepared PDF if the Mods want to add the data to the FAQ):
The Layouts Follow THIS Format:
Body Control Module (BCM) C#
Pin Wire Color Circuit No. Function
Body Control Module (BCM) C1
Connector Part Information
OEM: 12110088
Service: 15306210
Description: 24-Way F Micro-Pack 100 Series (GY)
Terminal Part Information
Pins: A2, A3, A4, A5, A6, A12, B1, B2, B3, B4, B5, B6, B7, B8, B9, B10, B11, B12
Terminal/Tray: 12146447/3
Core/Insulation Crimp: E/C
Release Tool/Test Probe: 12031876-1/J-35616-6 (BN)
A1---- Not Used
A2 WH 2282 Headlamp Washer Relay Control (CE4)
A3 OG 1140 Battery Positive Voltage
A4 BK/WH 1969 Headlamp High Beam Relay Control
A5 PK/WH 1970 Headlamp Low Beam Relay Control
A6 PK 5363 Inclination Sensor Low Reference (BAE)
A7-A11 ---- Not Used
A12 WH 278 Ambient Light Sensor Signal
B1 L-GN 1037 Class 2 Serial Data
B2 BK 279 Ambient Light Sensor Low Reference
B3 L-GN 2270 Rear Window Washer Relay Control
B4 GY/BK 2226 Instrument Panel Lamps Dimmer Switch Low Reference
B5 GY 705 5-Volt Reference
B6 WH 2283 12-Volt Reference
B7 OG/BK 2090 Courtesy Lamps Supply Voltage
B8 L-GN 1011 Remote Radio Control Signal (STW)
B9 GY391 Rear Window Wiper Switch Signal
B10 YE 1836 Security System Sensor Signal
B11 GY 2521 Right Sunload Sensor Signal (CJ2)
B12 L-BU/BK 2519 Left Sunload Sensor Signal (CJ2)
Body Control Module (BCM) C2
OEM: 12110112
Service: 12110112
Description: 32-Way F Micro-Pack 100 Series (TN)
Pins: E3, E4, E5, E6, E7, E8, E9, E11, E12, E14, F3, F4, F5, F6, F7, F8, F9, F10, F11, F13
E1-E2 ---- Not Used
E3 L-GN 80 Key In Ignition Switch Signal
E4 YE 307 Headlamp Switch Flash to Pass Signal
E5 GY/BK 308 Park Lamp Switch On Signal
E6 PK/BK 109 Hood Ajar Switch Signal (UA2)
E7 PK 1348 Headlamp On Indicator Control
E8 BK 1835 Security System Sensor Low Reference
E9 RD/WH 812 12-Volt Reference
E10 ---- Not Used
E11 D-GN/WH 1317 Fog Lamp Relay and Indicator Control (T96)
E12 BK 28 Horn Relay Control
E13 ---- Not Used
E14 TN 5463 Daytime Running Lamp Override Indicator
E15-E16 ---- Not Used
F1-F2 ---- Not Used
F3 D-GN 113 Windshield Wiper Switch Signal 2
F4 D-BU/WH 1495 Courtesy Lamps On Signal
F5 BN/WH 1871 Headlamp Washer Switch Signal (CE4)
F6 OG 192 Front Fog Lamps Switch Signal (T96)
F7 L-BU 187 Rear Fog Lamps Switch Signal (T79)
F8 L-GN 5462 DRL Defeat Switch Signal
F9 WH 103 Headlamp Switch Headlamps On Signal
F10 L-GN 11 Headlamp High Beam Supply Voltage
F11 PU 328 Interior Lamp Defeat Switch Signal
F12 ---- Not Used
F13 PK 5068 Intrusion Sensor Switch Disable Signal (BAE)
F14-F16 ---- Not Used
Body Control Module (BCM) C3
OEM: 15354796
Service: See Catalog
Description: 40-Way F Printed Circuit Flexible (GY)
Pins: A1, A2, A3, A4, A5, A6, A8, A11, A12, A13, A14, A15, A16, A18, A19, A20, B1, B2, B3, B4, B5, B6, B7, B8, B9, B11, B12, B13, B14, B15, B17, B18, B19, B20
Terminal/Tray: See Terminal Repair Kit
Core/Insulation Crimp: See Terminal Repair Kit
Release Tool/Test Probe: See Terminal Repair Kit
A1 -- 2140 Battery Positive Voltage
A2 – 2140 Battery Positive Voltage
A3 – 748 Right Rear Door Ajar Switch Signal
A4 – 1134 Park Brake Switch Signal
A5 – 195 Door Lock Control
A6 – 2265 Power Window Lockout Left Rear Control
A7 ---- Not Used
A8 – 747 Left Rear Door Ajar Switch Signal
A9- A10 ---- Not Used
A11 – 1350 Ground
A12 – 1353 RAP Supply Voltage
A13 – 194 Door Unlock Control
A14 – 1080 Park Lamp Relay Control
A15 – 5168 Power Sounder Enable Signal (BAE)
A16 – 5204 Intrusion Sensor Data Signal (BAE)
A17 ---- Not Used
A18 – 992 Ignition 0 Voltage
A19 – 39 Ignition 1 Voltage
A20 – 541 Ignition 3 Voltage
B1 – 230 Instrument Panel Lamps Dimming Control
B2 – 230 Instrument Panel Lamps Dimming Control
B3 – 690 Courtesy Lamp Supply Voltage
B4 – 2240 Battery Positive Voltage
B5 – 1186 Power Window Switch Right Rear Up Signal
B6 – 2266 Power Window Lockout Right Rear Control
B7 – 1188 Power Window Switch Right Rear Down Signal
B8 – 1185 Power Window Switch Left Rear Up Signal
B9 – 1187 Power Window Switch Left Rear Down Signal
B10 ---- Not Used
B11 – 1350 Ground
B12 – 24 Backup Lamp Supply Voltage
B13 – 4440 Battery Positive Voltage
B14 – 1382 LED Dimming Signal
B15 – 543 Accessory Voltage
B16 ---- Not Used
B17 – 4040 Battery Positive Voltage
B18 – 1732 Courtesy Lamps Supply Voltage
B19 – 1977 Rear Fog Lamp Relay and Indicator Control
B20 – 5362 Incline Sensor Signal (BAE)
Additional BMC Layout Images:
View attachment 113084View attachment 113085View attachment 113086View attachment 113087View attachment 113088View attachment 113089View attachment 113090View attachment 113091View attachment 113092View attachment 113093View attachment 113094View attachment 113095View attachment 113096View attachment 113097
Thanks so very much for your effort. This is the first time I have seen information regarding the identity of the BCM connector interfaces. I do not have a service manual so relying entirely on the wiring diagrams provided by mooseman. Maybe the BCM fully documented in the package provided by mooseman. I never checked that, my oversight if that’s there. Previous to your reply, I had no idea as to connector identification or location.
