I have a lock up issue on inclines when traveling at highway speeds. It now rumbles more often and is more severe than in the past. I manually drop it to 3rd to avoid the rumbling.
Otherwise all shifts are normal and crisp. I have a tune with a "firm" shift which was suggested by PCM for less. The vehicle has 173K on the clock and about 150K on a totally rebuilt trans that carpped the bed under warranty.
From what I have researched, the best fix is to replace the valve body as the bore for the TCC valve gets worn causing the shuddering. The one I'm considering is adding a new seat and a SONNAX TCC valve to the valve body as well as a few other enhancements and parts changes. See link below
I have never changed a valve body before but have done all sorts of major work on cars so I'm confident that I can do the job correctly.
My hesitation is can I do this with the tranny in the vehicle in my garage?
Also, am I going overboard with the replacement of the valve body? From what I've read this is the proper way to correct the issue, other solutions are only band aids and may cause issues with the 1-2 shift and eventually cause the trans to fail.
Lastly, am I crazy to do this at all and should I just bite the bullet and get a remaned trany? IE 150K on the current unit.
Thanks!
http://www.ebay.com/itm/4L60E-4L65E-03-06-M30-VALVE-BODY-SONNAX-REMANFACTURED-REBUILT-CONTROL-VALVEBODY-/261293225781?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AEnvoy&hash=item3cd64a3735&vxp=mtr
Thanks!
