I just installed these taillights I bought from ebay.
[EBAY]190836751729[/EBAY]
Just a no-name, made in Taiwan set of taillights. Mine were getting water infiltration and I wanted LED's so this was the perfect solution. What I didn't notice in the ad was that there are load resistors included. Sweet!
There were no installation instructions but if you don't know what you're doing, you shouldn't be adding LED's . I put the load resistors, which have double sided tape, in the empty space just below the taillights, as in the pic. A couple of hiccups though. The brake lights didn't work at first. Simple enough, just flip the connectors around. Then, the LED parking lights would flash with the signals. Flipped the signal light connectors around, sorta helped but they still flash very dimly. Seems to be worse with the left signal than the right. Once the brakes are applied or the parking lights are on, they don't flash and everything else works as it should.
I will contact the seller to see if there is something I might have missed but I doubt it. Also, he jacked up the shipping charges to Canada to $60. I got them shipped here for $17 + $19 for taxes.
