So I've done a lot of research trying to figure out why my car stalls and has trouble starting after i fill up the tank. I've heard its because the fumes from the gas is going right into my cylinder combustion choking the engine. bad purge valve? I replaced my purge and vent valve already. It could be the new purge valve is faulty? Also I have been getting bad MPG as well. I also have engine codes stating that there are large-small evap leaks. Two separate codes. Trying to get the vehicle to pass inspection next month. doesn't really have a rough idle anymore for whatever reason. Also sometimes when my car idles and just reaches operating temp, it'll stall out. My buddy gave me a brand new oxygen sensor but I don't think that has to do with anything so I haven't replaced mine yet. can I blow in a purge valve to see if its stuck open, or is that trick just for the vent valve? Also when I'm fueling gas or if i start my car I can smell gas fumes around the vehicle.
Any suggestion on what I should do or where to look would be amazing!
Thanks!
Thanks!
