- Nov 22, 2014
- 16
I've been trying to tackle this knocking noise for a while now. Others have touched on this topic with no final outcome, the topic seems to get put on the backburner.
I have had a knock, the same knock that if you clog the crankcase ventilation hose, dissipates after a minute.
I haven't thrown any codes, however I am wanting to resolve this issue prior to it causing major problems.
I have attached a copy of my OBD2 readings when the TB was up to temp.
So far I have attempted the following...
Camshaft Position Solenoid
O2 sensors
Fuel Filter
Fuel Pressure Regulator
Spark Plugs
Air Filter
Belt and Tensioner
Evap Purge Valve
Vapor Vent Solenoid
Gas Cap
Cleaned Throttle body (removed)
I do not claim to be knowledgeable on this, I am learning as I go, so be easy on me.
I've attached my obd2 readings if that should help. Ill take anything I can get and greatly appreciate everyone's time.
O2 sensors
Fuel Filter
Spark Plugs
Air Filter
Belt and Tensioner
Evap Purge Valve
Vapor Vent Solenoid
Gas Cap
