K&N cai replacement filter
Ghost
Anyone here have the kit on there TB ? Ever thought about using this larger filter: RE-0920 ?
benz01 said:
I have this kit on my I6
http://www.knfilters.com/search/product.aspx?Prod=57-3036
Not sure how much bigger a filter you can get, there's not a lot of room with the filter that comes with the kit.
Me too but I got the chrome kit used and my filter is trashed. Seller didn't specify filter condition. So I figured id go with the larger filter... just curious how the performance will be good or bad with a a larger / longer filter ? I also modified my stock box top to go over the filter just incase rain doesnt got on it plus it baffles some of the sound.
I personally didnt like the airaid filter from the airaid cai, so I went with an AEM dryflow filter,
easier to clean and no oil
K&N and AEM joined forces to make a cleaner kit for AEM dryflow filters, it a nice size cleaner and will last a long time
Maybe avoid the K&N since they let more dirt in. Since you need a new filter you can get one that actually filters.
Ok, so if I understand this correctly the consensus of this board is that K&N air filters do increase air flow but sacrifice the ability to properly filter the air into the engine. Is this just the come filters or does this include the drop in filters as well?
Okay can someone link me to a airfilter the doesnt let in dirt that will fit my k&n intake pipe on the tb ? Note: I seen k&n sells a mesh bag that goes over the filter...hmm
I thought I read that even if you use the dry cover on the K&N you still have to oil the filter but I'm not 100% sure on that.
Google Cold Air Intake and there are a few options that have a dry filter option. Anyone on this board use a dry filter, cold air induction?
That mesh cover is to keep the big chunks from clogging the filter.
I have a wire mesh filter...but u have to understand my vehicle is strictly street use and there can be dust getting into my filter but ill order a different filter and see how it does. I clean and re-oil my k&n every 3k miles
I have a writeup showing how well my Green filter works. The pics show how well it really works.
Pm me with it thanks
Try the search button. Thanks.
I had a K&N on a truck and it destroyed my MAS. The 03 TB doesn't have MAS but I think with the trottle body issues they have it couldn't be good to get that thing covered with red sticky goo.
I coulda swore the red oil goes on the outside...iv used k&n on all my dirt bikes, go peds go karts...iv never had a problem. To each his own I guess.. tho aem is going to be my filter for the tb. Just so everyone is happy.
I am running the 21-204dk aem filter on my airaid intake. I hope you dont have any clearance issues seeing that the filter you chose is 3" taller than mine.
21-2038DK - AEM , AEM DryFlow Air Filter
VS
21-204DK - AEM , AEM DryFlow Air Filter
Took a pic of so you can get a visual:
rmsg0040 said:
pic can be found on google, type in airaid trailblazer
He wants to get a look under your skirt! Good idea directing him to all the free TB porn though
Lolol
Here it is guys:
The filter is huge !!!!! Going to reset the pcm real quick since its used to the dirty junk k&n filter. It fits just how I wanted it to.
Here is the old k&n filter:
chinotino
