just did a tune up
psycho91
62
OK so I just replaced the plugs and I'm doing an oil change later in the week, I do not know what else has been changed or done as far as fluid/filter/belt changes and such, what else should I do to keep this beast in tip top shape
Rubberman
117
Fuel filter, it's any easy cheap maintenance item . Air filter too.
psycho91
62
Its got 109,000 miles on it, also I changed the plugs and they were gapped at. 40 so I left them alone and put them in, and its still running like its misfiring, I had no choice but to drive it with the misfiring plugs for about two weeks, I'm lost on what to do, has it caused major damage to my motor
CdnGMan
1,393
Toronto
Did you use the CORRECT plugs for the Voy? The AC Delco ones? :undecided:
Misfiring can damage your catalytic converter. You need to ONLY use Delco 41-103 plugs.
psycho91
62
As bad as I wanted to throw some ngk's in there I did the smart thing and went with the 41-103's acdelco's, I tried disconnecting the battery to see if that would work cause IV heard that can help and it did nothing, IV also heard it might take 100 miles or so for everything to smooth out
Fuel filter is not an easy thing on any but 02's....
With 109000 miles on your truck both differentials, transfer case, and transmission fluids will also need attention if this has not already happened.
psycho91
62
I believe I found the culprite, little no engine oil, idk where it all went as I check it periodically religiously, and I plan on changing all the fluids as soon as I get the chance and the cash
Rubberman said:
My 04 was easy. pop off, pop on.
I thought after 02 they were all in the fuel tank???
Good to know. Had it in my head that only 02 had an accessible filter.
Black_tb
817
my 04 has a accessible fuel filter
seryi2035
