Voymom
- Joined
- Feb 3, 2012
- Posts
- 2,523
I have memory seat function, however it only works 50% of the time and when it does not work a good slamming of the door seems to fix the issue. I noticed that when the function is not available for whatever reason, the light on the button is not on either. A good slamming of the drivers door...sometimes a few slams makes the light come back on and the memory seat function to work properly....any reason why this is?
I thought maybe a loose bulb, but a bulb obviously doesn't control whether the option works or not, so then my second guess would be a short or loose wire somewhere? Any thoughts?
Also, I have the same issue with my stereo, it's OEM BOSE upgrade single disk CD bay. I have a few lights which hardly ever work unless I pound pretty hard on the center dash, but the buttons still work regardless if the lights are on or off. Took the radio out and the bulbs are fine, but there seems to be a burned spot on the radio screen. I plan on putting an after market radio in soon, so it really doesn't matter, I just want to narrow down any electrical problem if there is one, and a way to fix my damned memory seat function before I need to replace my drivers side window for slamming the door to hard out of frustration UHG!
Thanks again!
Thanks again!
so what would I be shopping for a new DDM? And how hard is it to change out and or clean?
my wife complains about the samething but she better not slam Mayo's doors
That's why I programmed the passenger seat just for her
