Recently found a couple issues going on with my 05 Tb Ls EXT. just had my tranny rebuilt ($1700 I was not accounting on...) and now I find myself having some weird startup issues. I have the later end of 05 trailblazer and the non serviceable fuel sock attached to the fuel pump in the gas tank. The other day I was getting some weird rpms (cold morning startup usually 12-1500 rpms) and it went straight to 600 rpms from 1200 rpms after about five seconds. Ran kinda rough so turned it off and tried to turn it back on again. Nothing. Engine turned over repeatedly but no start. 3-5 minutes went by and finally started by pumping accelerator repeatedly. Worked fine after that, but this has happened before. I have about 180k miles on this guy now, and I am wondering if maybe the fuel sock is clogged or pump is failing, (hasn’t been replaced at all as far as I know). Anyone have any thoughts on what might be causing this? (Fuel gauge just went past full and is staying put too, heard it’s in the same place as the pump). The issue of the TB running in low-rpm mode is becoming more consistent. Used to be every so often with cold start, then every cold start, now even when warm too. Misfired here and there too, all with no Check Engine Light. Idles now warmed up in low-rpm mode under 0 rpm still running and no engine roughness. Pretty baffled by all of this. Read somewhere it might be the Cat, but anyone else have any thoughts?
