Inflator light
Machoman
123
A couple of days ago the compress stopped working on my Envoy. I have checked every fuse that the compressor uses. The light on the inflator button is blinking. The manual say that this is because of overheating. I find it hard to believe being that it is near 0 deg. out. I remember reading somewhere that the blinking is an error code. Does anyone know what this code is? I am getting one blink pause then two fast blinks…repeat.
Maybe it's just dead. Did you try pulling the fuse to reset it?
If you have a bluetooth OBD adapter, you can use Car Gauge Pro on an Android device to read any body codes. If there are any, it should pull them up.
northcreek
3,374
WNY
Overheating is a constant quick flashing. 1-flash is a compressor problem, 2-flashes is a left sensor problem, 3- flashes is a right sensor problem.
Probably your compressor unit is toast, they are pretty much unrepairable other than a check valve and that's not your problem.
The unit also contains the brains of the system...Mike.
ps I bought mine from Arnott.
northcreek
3,374
WNY
The 113" wb compressor unit is behind the pass rear wheel. You can't pull up any codes as the system is a stand alone...it's all in the compressor unit and I don't believe it interfaces with any other systems.
NOTE: it does get input from the VSS.
Machoman
123
Today I replaced the compressor with a brand new Arnott compressor. Installation wasn't too hard. The tube with the white compression ring was a pain. Problem, the compressor still won't turn on. Anyone have any ideas? My rear end is now all the way down.
northcreek
3,374
WNY
I checked my manual and there is no start-up procedure after compressor replacement, should be plug n play. Other than the 30A fuse I can't think of anything other than the obvious gremlins. I would give the electrical connection at the compressor a good look that thing is in the worst possible environment, check for power there also.
I'm assuming that you got the correct unit for your wheel base...Mike.
Machoman
123
I have the correct compressor. I'm guessing the is a cut wire somewhere. Unfortunately the wire diagram doesn't show where the wires are ran.
northcreek
3,374
WNY
The black wire from the 8 pin connector relies on a chassis ground, make sure that you have that before any other probing.
northcreek
3,374
WNY
TShepherdENVOY 03 XL
