HVAC Blend Door Actuator (Floor to Upper Vents Actuator)
Maverick6587
730
Sterling Heights, Michigan
I replaced this actuator last year with one from the junkyard. I'd like to not have to do that again for a few years.
Does anyone know the ACDelco part number for the blend door actuator that switches the airflow from the floor to the upper (face) vents?
It is just the center upper vents that never get any airflow. I have already done the HVAC reset and the actuator does not make any noises when switching the control from floor vents to the upper vents. I believe that is the actuator that is under the driver's side and the uppermost actuator above the brake/accelerator pedals (the same one I replaced last year).
The floor, windshield, and the side vents are all working and have air coming out of them.
I assume it is part # 1573596 but, I would like to be sure before ordering the actuator.
10,685
Here you go :book:
90455
33chevyrod
