purchased 2006 New from Dealership. 7 years later at 84,000. Only big things i had to change were the fuel pump and that window switch. (soon)
purchased my '07 on Oct. 20th, 2008 with 9400 miles on her, 4 motors later, she's now at 46,000 miles on the body and 0 miles on the new crate motor...
I just saw this thread and realized I missed the 100.000 mile odometer picture, oh well. I just looked and I'm currently at 100,462 miles. I bought it in April 08 and it had 27000 miles on it. Engine was replaced with a new one at 53085 miles. It's been nothing but a constant pita to maintain. Lots n lots of new parts on it. Paid $24,000 for it and it has had about $12,000 in maintenance/repairs so far, the new engine being $7500 of that thank god for the extended warranty. Outstanding are 2 front wheel hubs and something still clunking underneath. Transmission fluid/filter will also need doing now, transfer case and diffs are done.
I get the feeling Denali n DOO will be getting a separation real soon :frown:......and I'm definitely not getting rid of the DOO!
Purchased in 2008 with 15,000 miles. Currently at 119,000 miles and still running strong!
Where in WV are you at?
And to keep it on topic, 97,800 on my 2004.
Hit 175,000 today. As long as the body holds together I hope to get 250,000+ out of it, but the rust is eating through the seams in the wheel wells now. Probably getting a little water behind the interior panels in the rear cargo area and some holes aren't far behind in other areas :sadcry:
Wanna buy a Denali? It originally came from Bob Daniels GMC in Columbus Ohio. I think it's been home sick ever since I bought it, and I think it wants to go back to Columbus where it came from...
hit 153k today, hope to have many more miles down the road
I don't have any money right now. Especially not enough for what that one is worth.
BTW, your clunking could simply be the end links. Stupid things. I think one of my rears loosened up on me as I'm hearing a familiar noise back there similar to what I heard in the front last fall before I cranked the nut back down again.
Currently in Martinsburg. Just moved here about nine months ago for work.
Just hit 110,000 on mine this week.
172,000 today. Purchased in July 2009 with 57,500.
Bought new 04/30/2007. Currently has 71,600 miles on it.
Bought my 05 TB in 09 with 40,000 miles. Just rolled over 93k. Running like a champ still and hope for many many more miles.
I bought my Envoy new in 2002 and just recently broke the 58k barrier.
new wife and i traded her 2003 kia sorento in last year since it was only a 5 passenger. found a 2003 fully loaded envoy xl with everything on it and 4x4 with 100,000 miles. found original sticker in glove box. thing listed for 40,000 brand new. with trade in we paid 5400 for it in april 2012. now it has 113,000 miles. things i have done since getting it are
1. added some freon
2. replaced rear air bags and shocks
3. replaced spark plugs
4. cleaned throttle body
in next month i need to change clanking front sway bar end links and change original front shocks, and change tranny fluid, rear diff, front diff and transfer case oil.
other than that, no problems with it, runs like a top. averages around 19.5 to 20 mpg on the higway and about 14 in the city.
125k This week. Bought it new in March 2003. Motor is still going strong. I redid the suspension so hopefully I'll be good for another 100K.:thumbsup:
My 2002 TB has 126K Km (about 78K Mi), purchased on Jan. 2003, it has been running great.
Work done:
Fan Clutch (under warranty)
Fan Clutch
Thermostat (while at it Temp Sensor)
Oil changes every 6K Mi (I only use 5W30 Synthetic)
TB cleaned a few times.
A few Fuel filters
Fuel Injectors Cleaned
To be Done: Replace PCM, since last Fan Clutch Replacement can't get the P1484 DTC to go away, PCM needs to be updated to fix this, and it can't be done.
Considering this is 0ver 10 years old, I've done pretty much nothing to it, except scheduled maintenance, fan cltuch t-stat and soon the PCM.
117k
Going to hit 100k miles of ownership on my next drive! Also, next month is the last payment! I'll get organized and list everything that was replaced/repaired when that happens. Nothing out of the ordinary and a FEW common problems many of you have dealt with, sometimes more than once. Bone stock with a K&N air filter. Rattling trash can is still there, only bc I'm too indecisive of what I want back there... I'll cut it off when its "annoying" to me. Being hard of hearing helps! LOL
103,400 as of today.
All I have done is put in 2 ignition switches, front drivers side pinion seal and put up with a possessed instrument cluster from time to time. All fluids changed per the manuals recommendations if not sooner.
Pansies :biggrin:
J/k- I wish it was 150,000 lower...
My ride is just about 6 years old, got it brand new, and it currently has about 32,000 and some change on it.
zamimj222 said:
I bought my 2004 Envoy in Sept 2010 with 99,000 on the odometer. It currently has 140,500 miles. When I bought it from the dealership the only PM things I have had to do besides normal oil changes, replaced the spark plugs twice, first time at 100,000 and last time at 140,000. Replaced front, rear, trans and transfer case oil at 100,000. Haven't touched the brakes yet. The dealership may have. The front driver side wheel bearing has been replaced. Replaced the spare tire winch. Replaced smog pump under driver's side of truck and have the air valve coming that is off the exhaust manifold. Still running strong and just like the day I bought it!!
I now have 148,000. I have replaced the driver's side wheel bearing again, the smog pump again and the pcm. The truck is running great and almost paid off now so I am hoping for no more problems...:crazy::thumbsup::rotfl:
2004 Envoy XUV, 4wd, 5.3L, 154,600 and mostly still all original. Had to replace the midgate window regulator yesterday. I'll be needing to do the struts and shocks sometime soon.
CustomSix9
