Help with DRL killer
03luvvoy
51
To do the DRL killer mod what relay works for this I got a headlamp relay will that work?:confused:
03luvvoy
51
So I'm probably wrong with the headlamp? Sorry when it comes to vehicle electrics I'm lacking a lil bit lol
10,685
As long as you can make the required connections as instructed in the DRL killer thread, then you can use that relay. :yes:
03luvvoy
51
So as long as I have the 4 hook ups for the female ends to go on its useable?
10,685
:coffee: As long as you understand the connections to the pins on that relay you have, and how they relate to the pin assignments on the type of relay in the write up... The numbers may be very different, so you need to be comfortable knowing which pin does what. Once you've got those bases covered, then what you use to make the connections to the relay come into play. :twocents:
03luvvoy
51
Well shoot I have never really been to comfortable with vehicle electric I'll see if I can figure it out loo thanks a lot for all the input and help!!
moscoreli
