Please don't be offended by this suggestion... but just on the outside chance that you may have accidentally Installed the Rear Crankshaft Seal
Backwards... Take a moment to review this Video I made that clearly displays some very uncommon views of that same seal ...from
BOTH Sides of a Used Rear Seal Plate.
When played at Half Speed... Search your memory for whether or not yours looked like this OEM one. Featured in this Video is also a Brand New Plate and Seal Combo for you to likewise peruse and inspect and compare them to your own work:
There is also the possibility that if there is any Nick or Damage to the outer orbit of the Crankshaft Tail Journal Race... a
nd I do mean ANY Damage... it will quickly chew into and destroy the integrity of that New Seal and allow Motor Oil to get slung free as the Crankshaft Rotates.
The last possibility is that the Rear Crankshaft Main Babbitt Bearings are so badly worn that the Crankshaft can *Wobble* about in an elliptical orbit and break the ordinary seal that a perfectly circular one provides.
