- Jun 21, 2014
- 43
So here's the skinny...
2004 TB EXT 4.2 I6. MAJOR coolant leak that was causing the vehicle to overheat. I isolated the problem to the Heater Control Valve (HCV). After much wrangling with those damn OEM hose clips (they're truly the work of the Devil himself), I got the old/bad part removed. I have decided that while I'm at it and since the car has 150K+ miles on it, I might as well replace the 3 heater hoses that connect to the HCV. One small problem. CAN'T FIND THE DARN PARTS!
Looking at the diagram below, I need parts # 9, 19, and 21.
Multiple searches of autozone, O'Reilly, Napa, etc have hoses, however they're not the pre-molded hoses, or you have to cut them to fit and so on. Even http://parts.nalleygmc.com/ where I found this diagram doesn't have them listed for sale. So, anyone else ever replace these hoses, and if so, from where? What part numbers exactly am I looking for here? Much thanks in advance!
