headlight height adjustment!!!!!
trailblazer075
323
LAGNY SUR MARNE FRANCE
Hello everyone!
I have a problem with the headlight height adjustment, it does not work, do you know where is the connection for me to check if it is unplugged.
Neither one works.
THANK YOU
Canadian Mike
738
trailblazer075 said:
Hello everyone!
Neither one works.
THANK YOU
I had the same problem but only the passenger side. From my posting on the OS of almost a year ago.
Broken Adjustment Screw
Well I figured out why my passenger headlight would never align. I turned the torx screw and it wouldn't adjust. The adjustment screw is broken.
Now I'm thinking,
- Can the adjustment screw be turned with pliers alone?
- Can I get another adjustment screw?
- Check the junkyard for a used headlight assembly?
- eBay?
I just quickly snapped this from my cell, tonight.
regulator1175 replied and I followed his suggestion, twist-ties.
I'm still using this fix.
trailblazer075
323
This weekend I removed the optical right and I think I made ​​an unplugged by mistake.
I'll try to find her.
At the same time J have found that the supply pipe was broken headlight washer I'll take the opportunity to fix that too.
Yasha
