I have the materials available to make another one of these custom sub boxes. It is similar to the JL stealthbox or subthump boxes. I will fully customize the size to fit the specs of your sub, and can play with the height/width to make it work with the cargo shade if so desired.
About the construction:
-hand made from 3/4" mdf, glued/sealed, and screwed
-recessed into side compartment
-still allows the inflator to be used, just need to slide box out of way
-tight fit in recess and the weight of the box locks it in place, no external mounting features needed (i've done doughnuts in my truck and it doesn't move)
-includes terminal cup with soldered wire leads to hook up directly to your sub
-carpet match as close as I've been able to find for our interior (2nd box I built with square hole)
-carpet will be one solid peice on face, sides, etc, all areas that are seen when installed
-I can fully carpet the back side but it will be pieced together
-recessed area is carpeted to give tight slip fit and protect from scratches
-I have close to 20 man hours in each box start to finish and this is a hobby so please be patient on construction time
If you are interested shoot me a PM. I need to know the exact sub model# you will be using to properly size the box and cutout.
I haven't done ported boxes, don't really know much about port design. If its something you want done, we can discuss but it will be additional cost.
I will do all this for $325 shipped to the lower 48 and I'll cover the paypal fees. JL box is 650-150(sub) = $500.
Details from first build here: It's hard to think outside the box, when all you think about it box... - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
