I have a problem.
Just got home from the yearly inspection.not approved because of a new rule.
You see, i have a child seat in the front pass seat. Therefore i have disconnected and removed the airbag for obvious reasons.
I have for two years driven with the airbag removed with no problems at the inspection before.
Since January 29 there is a new rule against having the SRS system indicate any fault here in Sweden.
I have heard of a plug that you can put in the connector instead of the airbag to fool the system to think the airbag is there to get the system to function as usual and not getting any airbag warning lamps or messages about service airbag system.
Have anyone heard of this before????
I must solve this because i dont want to have to install the airbag and remove it again every year.
I know there is a plug used by dealers to test the system somehow, but that is a expensive piece. There should be a simpler plug with the same resistance as the airbag, at least what i heard.
Please help!!
Please help!!
