My 2003 LT 4.2L Trailblazer has developed a leak at the rear of the fuel tank where the check valve is plastic welded to the tank. Fuel seeps out at this "seam weld". At 140,000 miles I suppose I need a new fuel pump also. So I ordered a Delphi unit from Summit Racing including the sending unit and the OEM style rubber sealing gasket.
Anyhow...this is a regular length chassis. There was an warranty repair for this on EXT units. Regardless mine isn't EXT and I'm past the year/mileage cutoff. Personally speaking...I feel that this is a pathetic failure of the fuel tank design. I've had to fix alot of things in my life (the most recent being replacing the 4L60E in this TB because my torque converter came apart and pretty much destroyed the transmission with debris)...but I've never had to deal with a leaking poly plastic vehicle fuel tank on any brand, any vehicle. Oh well....here we go anyway.
The dealer wants $1200 for a new tank. And I hardly see how that will guarantee me it couldn't happen again. This truck is going to be with me until 200K miles. I'm not too far off now so a repair seems more like it. Between the new transmission and a new fuel tank...the vehicle is darn near in the "totaled" catergory financially speaking. The truck still looks and runs like new. So I'm not "totaling" it out just yet.
Once I get the tank out I plan to clean the area around the tank/check valve and plastic weld it using a plastic welding heat gun and HDPE black welding rods from Fastenal. I've been around welded plastic HDPE tanks and I've mig/tig welded before...so I think I can pull this off.
I've watched the videos available for plastic welding HDPE and it's not really that complicated. Just evenly heat the areas to around 500F (including the rod) and push the rod into the region working around the circle of the valve.
Anybody see any problems? Such as the tank isn't HDPE...I'm assuming it is. Or the check valve is very thin and won't take the heat? The factory welded it on there but with a tiny weld seam. I plan to put a nice wide bead around it and let it naturally cool overnight. Hopefully this will be strong and also stop any leaking forever.
PS: I'll drain the tank and let it air dry before this procedure. The weld gun is actually a hot air gun that focuses the heat with a tip. So there isn't any actual flame contacting the tank. But the air gun does use a heating element inside it so I should still be cautious of fumes etc.
