Fuel gauge not working
blackout51
157
I just filled it up and the gauge drops to empty, and stays there. My mom had this issue on her 2007 envoy and got something replaced at half cost because of some recall, mine is at 137,xxx so I don't qualify for the recall but I'm curious if the recall was for the whole fuel pump or just some other small part, any info is helpful
jrSS
Fuel sending unit.... mine is also bad. Reads E constantly. I go by how many gallons I use to know when to fill up.
blackout51
157
Is it attached to the pump or can I change it without dropping the tank?
blackout51
157
jrSS said:
U gotta drop the tank....attatched. nothing is easy these days
Well I guess at 137,xxx I'm just gonna drop the tank once and change the whole pump assembly and get it done with, are there articles on here on how to do it?
You could always cut a hole (in the right spot) in the body pan to get at it from above. Seriously, my gas tank armor would be so hard to take off that if I need a new fuel pump that's how I'm going to do it.
blackout51
157
That's an interesting thought, how would I go about lining the hole up right though? Or would I just have to cut a big enough hole and get a plate or something to make a type of door
blackout51
157
Triangulate from underneath to the frame and measure very precisely. Plenty of images you can find in a Google image search.
Here's a How-to on the OS, in case there is Google outage in your neighborhood. 2005 Envoy Fuel Pump Replacement - Part I - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum (I'm feeling particularly generous today.) :wink:
I know I plan on doing my own search I just figured while I was typing I might as well ask, but thanks those pictures help a lot. Is there anyone on here who has actually cut a hole in their floor?
Fire06
7,223
I dropped my tank and replaced the whole unit as a complete part. It was not really that hard to do. Just make sure that it is as empty as you can get. How to do the whole project is outlined here at the site.
blackout51
157
What did you use to get the quick connect point off? Those are my main worry, I have broken them before and that was the worst repair I've ever done replacing that thing
Fire06
7,223
My fuel lines pushed together and were held in place by a plastic clip. You can get replacement ones. I replaced all 2 or 3 I broke. Once you get the hang of it they come apart. I think rockauto sells a kit of the clips or any auto parts store should.
seanpooh
461
There is a member who created a video about replacing the fuel pump and sending unit together. He also has many other videos posted up.
[video=youtube;I25z-7QQJcM]http://www.youtube.com/watch?list=UU3lA8nBEEZTOHknztk5xBRg&feature=player_detailpage&v=I25z-7QQJcM[/video]
Denali n DOO
5,596
My friend and I used this video to do his 03TB fuel pump. It was pretty easy job for us 2 non mechanic guys. Make sure the truck is up high enough that the tank will drop and slide out. We used a Bosch pump but didn't like the "O" ring provided so we got a GM one to use. No broken clips on fuel lines.
jesussaves
