front right light fixture
carl r
us
after a repair shop installed new water pump and belt i have no working lights in front right side. What could they have done to cause this?
Could you provide more specifics? Is it just the low beam/DRL? Or is it also the lower and side turn signals?
Shotgunning some troubleshooting steps, I would check the plug connections, look for damaged wiring, or blown fuses. Those conditions determine what comes next.
all four lights are not working right side front , no blown fuses, no visible wire damage
This Video from @MAY03LT covers ALL of the recommended Diagnostic Procedures for Headlamp Bulbs, Lights, Powers, Grounds, Fuses and Relays:
Tools Required:
(1) Large Screw Driver
(2) Lighted Pin Probe
(3) Digital Multi-Meter
If nothing works, I'd look at the ground wire.
labura
