- Dec 5, 2011
- 597
Hello folks. Old time member but I haven't posted in quite a long time.
My 06 is in need of some TLC at tax time, and I am starting to work on getting myself a part list. I know it needs struts, and it will be getting Bilstein HD to match the chocks I put on the rear last fall. I know it also needs all 4 ball joints, and at least a set of new bushings in the SMAXX links. And I'll probably grab a set of sway bar mount bushings. What other parts should I consider replacing up front while that is all torn apart? It has 120K and is mostly factory with the exception of wheel bearings and brakes I've replaced multiple times. Let me know what you think. Thanks.
