Have a Trailblazer LS 2005 with Gu6 3.42 Front Differential which I am changing out.
So then what is easiest way or hardest? 1. Drop Oil pan & Rack, 2. Jack engine after removing mounts and jack to the passenger side
or 3. drain water, remove bat & tray, alternator hoses, thermostat & pull aside A/C compressor and pull diff up to the top?
Have read all three ways just curious of which do you advise. Thanks
