Front constant 12V Power other than DC outlets?
joeredspecial
68
I'm in the process on installing an AUX adapter (PIE GM12-AUX) that requires constant 12V power to function properly. On my old Trailblazer I tapped one of the DC outlets but I'm wondering if there are any other options for 12V constant power under the dash, specifically on the passenger side. For example, is there anything behind the glovebox or the kickplate? I've searched and looked in the service manual but I'm not coming up with anything. Thanks in advance.
joeredspecial
68
Tap into the radio 12v power. I think it's a pink wire and has constant power.
Thanks but I forgot to mention I'm specifically trying to avoid the radio harness. It's looking like the DC outlet might be my only option.
7,747
An additional "On Topic" Thread...
Reactions: joeredspecial
TJBaker57
2,900
Colorado
This is not on the passenger side but is likely an unused, fused power source. It is located at the far left under the dash along with a few other wires meant for the addition of a trailer brake controller.
joeredspecial
68
Thanks, I actually took the time to remove everything and to run a wire from the Rainsense fuse in the rear to add a PAC AAI-GM12 and an additional DC outlet on the switched 12V power. Unfortunately the PAC adapter's audio quality was poor so I removed the PIE adapter from my 2002 Trailblazer and installed that. It works well but needs constant as opposed to switched power so that's why I'm in this situation.
33chevyrod
