My current Envoy is 4x4 and has 197 K miles. Runs perfect. I'm second owner but know the original owner and all of the maintenance before I purchased it. I've owned it for 13 years and have done alot of work to to it. It has been meticulously maintained. With the exception of a little piston slap that goes away when warmed up, and a little bit of oil consumption, (1 qt or a little less in 4000 miles) The Envoy is perfect. My Envoy has the standard differential and is the 3.42 ratio. I installed a PCM for less transmission cooler.
I have a small trailer that I tow, 2900 GVW. The Envoy does OK as long as I leave it in 3rd. It lags on the long hills so was thinking the 4.10 might help in that area.
Only get around 12 MPG when towing but I guess that's normal. I do mostly desert camping and do use the 4x4 but not in extreme conditions. Mostly sand wash roads and canyons and some small hills.
Would it be worth getting the G80 and the 4.10 gear ratio? The dealer is asking $8500 which I think is a little steep but can probably get it for less. Also, what would be a reasonable offer?
I like the size of the std Envoy as it allows me to get into some tighter areas but am considering looking for a similar year Tahoe with the 5.3 and the Tow Haul feature for the transmission.. This is my dilemma. Any input is appreciated.
