DDonnie
- Joined
- Mar 26, 2012
- Posts
- 2,631
Alarm/RS Module w/blade Vehicle wiring
6-pin main harness, all connections at ignition harness
Red Constant Power | Red
Red/White Constant Power | Red/White
Pink Ignition 1 | Pink
Pink/White ignition 2 | White
Orange accessory 1 | Orange
Violet start + | Yellow
18 Pin Secondary Harness
Green Door Trigger | Cut – Handled by blade
Violet/White Tach input | Cut – Handled by blade
Black Ground | Factory ground, cleaned
Orange Starter interrupt
Brown/Red brake + | Factory trailer prep controller box, white wire
Black/White neutral safety | Factory Ground
Brown siren out | included siren +
White/black flashing light (-) out | grey/black at headlight switch
White flashing light (+) out | CUT
Gray hood trigger pin | Hood trigger pin (shouldnt leave disconnected, but can)
Violet door trigger + | Cut/handled by blade
red/white trunk | cut
Black/Red Wire Light Relay N/O (+/-) Input |12 volt constant from ignition harness
Green/Violet Light Relay COM Output |Brown Accessory 2 in ignition harness
White/Red Light Relay N/C Input |CUT
Violet/Black Horn Relay N/O (+/-) Input
Blue/Black Horn Relay COM Output
Brown/Black Horn Relay N/C Input
Blade hook up -
orange - Data | OBDII Purple
The part that is bolded, im not sure if i can do that or not, but it looks like it will work if i program the brain to use that as an accessory, can anyone elaborate?
The part in blue, im not sure how to hook up, same with the part in red.
Also, is there anything that I am missing that needs to be connected?
1830 - http://www.google.com/url?sa=t&rct=...wYDAAQ&usg=AFQjCNEPcDp_xsqVlclxATpDA7pyq4HLZg
Blade - http://www.google.com/url?sa=t&rct=...t7kK4Vgau9a5HWXyM_kzw&bvm=bv.1354675689,d.aWc
Blade hook up -
