We recently purchased a 2008 trailblazer (history unknown). First noticed that only one front passenger side speaker was working, then noticed that the 4x4 selector switch would only select 2wd. Then the dome lights would not extinguish and finally dash lights have gone crazy several times. (once while exercising the shifter - and another time while driving). Then every thing started to work - sound from all speakers, dome light and ajar indicator working. As I drove up our driveway and hit a small bump - everything went blank. After turning the truck off and let it sit for awhile - everything is working again.... (no engine warning or chk engine lights are on right now) although the intrusion indicator has come on and off.
The rear wipers also are not working nor is the rear washer pump. The wiper select switch rotates but doesn't appear to be doing anything.
I did replace the 4x4 selector switch with a new unit - same problem. This truck is equipped with remote entry - we did not get any fobs so I do not know if this feature works.
Just need a little guidance as to where to look first or what to check first.. Thanks
