So I was going thought my glove box today, and I came across this booklet, entitled Getting To Know your 2002 TrailBlazer. I was amazed that it had made it to this point in life, considering my father purchased this TB brand new in 2001. I was skimming though this book, and I came across a section on "Automatic Headlamp Control and Daytime Running Lamps". This is a direct Quote:
"Daytime running lamps (DRLs) make it easier for others to see your vehicle during the day. The DRL system activates your headlamps at reduced intensity when the ignition is on, the headlamp knob is in the automatic headlamp mode, and the vehicle is not in PARK.
When necessary, you may turn off the automatic headlamp system and DRL feature by following these steps:
1. Turn the ignition to RUN
2. Press the DOME OVERRIDE button four times within six seconds. A chime will sound to indicate that the system is off.
3. To return to automatic mode, push the DOME OVERRIDE button four times within six seconds, or turn the ignition to OFF and then to RUN again.
See automatic headlamp system and daytime running lamps in your owner's manual for more information."
I tried this today, and it worked in my 2002 TB LTZ. This may put an end to the need for a "DRL killer" mod for those looking to add HIDs, or like me, looking to add LED "eyebrow" lights ala Carlton aka Blckshdw. Try it out, and let me know what you guys think!
This option is usually suggested to noobs who installed HIDs without doing the proper research, and have asked how to get rid of their buzzing/flickering issues prior to getting a DRL killer. (if they don't wanna do the cap mod)
Well, at least I know now! I guess I need some info on that Capacitor mod!!!
always good to have more information available for others
