- Sep 6, 2013
- 35
New here, just took over driving my wife's 2009 Saab 9.7x after selling my GMC Sierra pickup. I work in telecom construction as an inspector, so I am in the field all day watching construction crews install duct for fiber optic cable, or watching crews install the fiber in the ducts. This requires something with ground clearance to be able to hop curbs all day, and be tall enough not to have the catalytic converter set a field on fire. It helps if the vehicle has limited slip diff, or even 4WD, as sometimes it gets muddy out there. So... when I sold my truck, the Saab seemed like it would fit the bill nicely.
Maybe.
I was backing up along a curb and did not notice I was by a broken catch basin (gutter) that had rebar sticking out, so I destroyed my right front tire. Fortunately, I had road hazard warranty, and it was replaced at little charge. I had a concern that this new tire would cause problems with the Saab's AWD system, as it would be slightly larger than the remaining tires that had around 35k on them. I quickly noticed a shudder or shimmy in my steering wheel at highway speeds (over 55) and started thinking it might be an AWD issue. Still, I took it in to the tire shop again and they rebalanced it and at my request, placed it on the rear. I noticed while it was on the spin balancer it was out of round. I knew then what the problem was. They claimed it would go away after re-balancing, so I humored them as I was short on time.
While there, I noticed my rear tires had a lot of wear on the inside, which would explain the "mudder tire" sound I got a low speeds. The shop tried to tell me I had an alignment problem, to which I asked how to align the solid rear axle. I recognized it was the same problem I had with my '07 GMC pickup with LRD- all the u-turns I make are shredding the insides of the tires. This is not my main concern.
Moving on, I notice the front end is now stable again, but I can feel a lot of vibration coming from the back. I return to the tire shop yesterday and describe all the above, and indicate that no amount of re-balancing will fix this. The tire needs to be replaced. They offered to get one in since it was not in stock, and offered a good price on a second so I would have two new tires on the same axle. I agreed, and then they offered to switch brands to something they had in stock so we cold take care of it right now. After some price haggling, I agreed. I drove home from the shop and I can say that all the vibration is gone, but something is different. Couldn't put my finger on it, but it was just an odd feeling.
Got home, no problems other than the weird feeling. Went back out and as I left my driveway, I notice the loud roar of the engine fan - at least I assume that is what I have been hearing all these years as my wife pulls out of the driveway. It was very hot yesterday- well over 100F, and so I figured to help the AC I would just keep the truck in 1st gear and let that fan spin on "hi". After it eventually settled down, I shifted up to "D" and when I reached the end of the alley, I had to brake a bit before turning onto the street. I again felt an odd sensation, and then a bump in the driveline as I accelerated.
I did not have far to go, and felt this bump every time I moved from a stop. I got the idea in my head that the rear tires are a bit different in diameter, and this is confusing the AWD system, probably causing it to engage. I then have the horrifying thought that I am burning up clutches as the AWD system engages due to speed differential- front vs rear- and I figure I better figure this out quickly before I create a larger problem.
Thus, I found this forum. Looked around and didn't find anything that fit my case exactly. I did take a crude measurement and found the rear tires to be 1" taller- 29-1/8" vs 28-1/8"
So now I am a bit frustrated, and curious. I am wondering if it is the tire size that is causing the problem. I am also wondering if there is a relay I can unplug to disable the AWD from engaging until I can solve the tire problem? I really hate to by the two additional tires as that will set me back about $500. I could give up the AWD for a while.
I also did not know about changing the fluid in the xfer case. I have about 65k, so I will be getting on that ASAP, and since I do so many u-turns, I will probably change the rear diff while I am at it.
OK, I know this is wordy, but I find in these situation if I dont give all the details, I get lots of questions, and I need an answer pretty quick.
Thanks to all who made it this far!
Maybe.
