Drivers door key cylinder problem
sunliner
365
I'm baaack...
Been using the key to lock/unlock the Snailblazer recently. this week, turned the key and the cylinder moves, but doesn't work the lock. the rod coming down from the lock cylinder has come loose from the latch. I'm assuming there's supposed to be a plastic clip on the lower end of the rod (can't find anything inside the door to take in for comparison) as I've replaced these before on other vehiclesbut I can't seem to find the part online...is it not just a "lock cylinder rod clip"?
sunliner
365
thanks Moose...from what I could see inside the door (not much) it looked like it might have been a 'special' clip. will see what Dorman can do .
It was @christo829 that helped you. Credit where credit is due :biggrin:
8,056
moscoreli
