Daytime running lights
retiredcopper
59
When I first purchased my 09 with one Tb w/I6 the DRL's weren't working at all,a swap of the dash sensor solved that problem. The other day I noticed the DRL's are operating at "FULL" power same as if the low beams were on. Anybody have this problem?...Please be advised I already swapped out the solid state relay in the fuse box with one from a friend's Tb who's DRL's are working properly and there was no change in mine. Any thoughts on what I can check next?...TIA
7,782
You might find THIS Thread... Interesting...
retiredcopper
59
MR,I had already gone thru these,were no help finding out why the DRL's are working at full power instead of the 50 or 60%...much appreciated for the post....I'll keep digging....stay safe!
10,687
It almost sounds like the 2nd daylight sensor failed the opposite way, making the vehicle think it's always nighttime. :undecided:
7,782
There IS a peculiarity with the Left Headlight, the Left Turn Signal and Fuel Pump Relay sharing a Common (Sketchy) Ground that can have an effect upon each other as per this image:
Also... The BCM (encompassed in the Dotted Line Rectangle on the Upper Left Side of this attached Diagram) seems intimately involved with the Headlamp Relay... so perhaps looking over the Fuses and Connection therein may reveal more possibilities... this Schematic commends itself to a bit of close study...
10,687
Blck,first I'm hearing of a 2nd sensor...might you know where it's located?
Sorry, I meant the sensor you used for the initial replacement seems like it failed.
Can you confirm if the parking lights are also on during the day? Or any of the interior lighting of the switches and dash are on?
retiredcopper
59
understood....and be advised all the other lights are working as they should
8,085
Possible someone did the DRL capacitor mod?
Fishermandude
