CV Axle stuck to hub
While I was doing my front end rebuild, I heeded the advice of 'tapping' the axle shaft inward to clear it of the knuckle (to avoid pulling it out when angling the knuckle outward) - but despite some (very) strenuous 'tapping' with the BFH on the axle nut (aligned w/ the end of the axle shaft) - I could not move it inward on either the driver or passenger side.
I got the work done, seemingly w/o incident (no detected issues with the axles when I drove it today). However, I want to eventually go back in, both for a leaking seal on the inner CV on the passenger side, and to perform maintenance on the disconnect module.
AFAIK, my hubs are OK (no movement / play, or noise). They're pretty well corroded in place (I didn't attempt to loosen or remove them - but I will, if that's necessary to free the outer axle shafts).
I would recommend spraying some PB Blaster around where the splines of the axle mate with the hub, from both front and behind. Let it sit a while, drive it some, etc. Then smack it again later. PB may help break it loose for you.
Thx, Sparky - I'm pretty sure I did the outer side, but doubt I did the inner. Will try that again in a few days.
(and it appears that this is my 500th post, as well. Yay me...lol)
Mektek
656
FL
Definitely soak it overnight with the penetrating fluid. You can heat it with a torch - just don't overdo it or you'll cook your hub.
Maybe you could fit a large 3 jaw puller?
linneje
404
I have used 2 jaw and three job pullers for various hub jobs. I don't know how I would do it otherwise - they very quickly work to free the splines from the hub. If you use a breaker bar with the puller, it takes very little effort.
Fishermandude
