Hi Guys,
2003 Envoy XL with DIC.
About a week and a half ago, i took my Envoy to get it detailed. The carpet was shampoo as well. This is when it all started. of course the carpet was still wet, the guys told me to drive around with the windows open so that it drys out completely. As soon as I drove off and turned the corner, i noticed that my dash gauges went crazy and the inside lights were on. i noticed that the security light was on and the DIC said, unknown driver. I drove back to the carwash and the manager said to get it a day for the carpet to dry out and see if everything goes back to normal. i agreed and left the carwash and proceeded to drive around with the windows open. i could lock the vehicle remotely so i didn't go anywhere that would require to leave the car unattended as the back hatch did not lock with remote cause the DIC didn't recognize any of the remotes.
The next day, I went out to the car and i was able to unlock the vehicle with the remote, I was glad that it was back to normal. later that day, i noticed that the mirror knob would control the passenger side mirror only, no matter which mirror is selected. even when the knob was in the center position. Didn't mind that too much and decided not to make a fuss over it. the following week i went out of town and the envoy stayed parked in the drive way all week. when i got back, I decided to use it the entire weekend and there wasn't any issues. the next day(Monday) i drove it to work, pulled up to the parking structure, pulled up to a stall and put it in park and pulled back the e-brake. i left the car on as i gathered my things and once i reached to turn off the car, as soon as my hand touched the cylinder, the engine shut off. it caught me off guard cause for one, the key was still in the "on" position, and two, i noticed numerous chimes but didn't pay too much attention to it. i removed the key and proceeded to work. lunch time came around and was going to drive out, but when i tried to turn it on, it would just crank and crank, and not start. it wasn't until i left the key in the on position that i noticed the numerous chimes again and when i looked in the dash, the DIC said Service Brake System. Now my car is stuck in an underground parking garage and it wont start.
I proceed to check a few things like fuses, battery terminals. I even replaced the ignition switch since it was a very cheap part to replace that everyone seems to point too but i get the same result. crank but no start. i thought about the fuel pump as i don't hear it come on when the key is turned to the on position but them what throws me off is the the Service Brake System msg that I've never seen before. I am not getting any SES codes, haven't scanned for ABS codes. Does the Service Brake System alert prevent the car from starting? that is whats keeping me from dropping the gas tank to check the pump. Im not getting pressure off the nipple so it seems like the pump is not turning on, but not sure if its a pump issue or its related to the Service Brake System message. The wisdom of the wise men is greatly appreciated.
