I seem to have fallen in a hole... :-(
I needed to change my engine oil in prep for a long trip (15% left on dic). Went to engage 4w lo to drive up ramps. Heard what sounded like actuator noises along with 4w lo light flashing (in neutral). Eventually, flashing stops, light status goes back to "4w hi" (not 2w which was original start state).
Try selection again, still no success. Decide to go up ramps in 4w hi... not that it will do much since there won't be any speed / clutching required.
Don't recall but I think I selected 2w and light flashes then selects 2w.
Change oil. Back down the ramps. Decide to try 4w lo again. Neutral, 4w lo flashing, don't hear much (not sure I was listening as close), light goes out but then "auto" is selected. Turn the selector to "2w". Flashing light but then "auto" stays selected. Now it appears that I can't get out of "auto".
Check fuses 8 (ATC) and 15 (TCM) with meter, good.
Changed the tranny and transfer case fluids in the fall as that vehicle had about 100k miles (bought used in the spring). Not sure of the maintenance history but the fluids looked (and smelled fine) and were at level. During the winter, things like traction control and such worked fine with no issues. Selected both 4w lo and "auto" in the over the winter with no issues. No trouble lights even now.
Probably look at the switch itself next, other suggestions along with double check of the transfer case fluids. I guess one question is will driving in "auto" in the summer cause issues.
Thanks for any additional suggestions.
