NEED HELP Changed Doors, airbag light won't go off. Ascender
mpbrown18
1
Houston
So I have a 2006 Ascender, someone rammed my side doors and I swapped them out with salvage doors. Since then the airbag light has been on. I'm sure that the side impact sensor is bad, not in the door at all or maybe removed before it was sold to me. Either way I took it to a body shop, they checked it with a CRP229 scan tool and got the codes below. I was told they tried to clear the code but it came back. The guy that was there also said he's not great with the scanner so take that for what it's worth.
All that to say - Is the side impact sensor (10369565) compatible with the Ascender? Everyone I talk to says they're not sure. I did some research on the codes and DTC81 is the side impact sensor.
Codes: DTC-23,01,80,81
That sensor seems to fit all 2006 GMT360/370 (TB, Envoy and Rainier), 4.2, 5.3 and 6.0. I would assume it's the same for your Ascender.
atza
