Capote's Build Thread - "BatBlazer"
Fixed that for ya big dog. :yes: :cool:
I see what you did there [emoji41]
jrSS said:
Looks great capote!! Just need to paint the grille to finalize the look.
Thanks brother, really considering it[emoji106]
Sweet looking. Hoping to get mine looking new at the end of the summer. Trading some services. I posted a pic for you in random pics.
Thanks Marc. Dude I didn't realize how horrible of pictures my phone takes. I need a new one, then I'll be able to get some good shots.
09 Aug 2015:
Re-done several wiring for LEDs, cleaned things up a bit under the hood, none are visible now. Put 2 5053 green strips directly on grill, hidden from view, so now there's a bright green ambient glow instead of those white strips I had facing out. Added quick discinnects so I can remove grill and still keep the strips in place. Washed and detailed interior, replaced ignition switch
14 Aug 2015:
Sanded, primed, wet-sanded, and painted the SS grill & bowtie gloss black (yeah, still have my original blue set aside)
Nicely done sir! That looks really good for a rattle can job. :tiphat:
Thanks Carlton, I really took my time to do everything correctly, especially sanding the primer to get it smooth before starting the layers of paint
Sib said:
Looks stealthy sweet! Nice work!
Thanks Sib, appreciate it[emoji14]
It does look stealthy doesn't it lol? I'm very glad to have taken the more serious, aggressive route when it comes to my rig
Reactions: Sib
Good work, Aaron! I guess Brandon used color matched paint for his. He told me he went though 8 cans iirc. Those guys are like $8 a pop.
Glad to see you made it work with Krylon.
Would love to see your rig in person but, from the pics it looks clean AF. Job well done!
Thanks Ryan, yeah he did. I don't use that stuff because its expensive. I've always used Krylon, really great stuff. The ones I used this time had built-in primer, so that was a plus considering I was already using auto primer anyway. I did all this with about 1 can, I switch cans when it starts to have difficulty at an angle.
Yeah she can be pretty clean looking, especially my wheels, spend a lot of time on them. When I can finally get this baby dipped and not have to look at horrible paint anymore I'll be extremely happy and a lot less concerned. Maybe then I will start looking for a car show somewhere. She'd look great at that point.
Reactions: SnowBlazer
16 Aug 2015:
Installed new front door speakers:
-2 - Pioneer TS-675M
Very good quality, they've got a nice bass to them as well. Was surprised how well they sounded, will be getting 2 more for the rear when they're in stock again ....at Walmart lol, yes I said Walmart
uploadfromtaptalk1439760908416.jpguploadfromtaptalk1439760942271.jpguploadfromtaptalk1439760959610.jpg
22 Aug 2015:
Installed the cheap eBay intake, I dunno how I feel about it yet. Now don't judge yet, Airaid is for sure of great quality & fitment, but I'm gonna run some tests to compare both. Visually it looks like this intake is a smaller diameter than the Airaid, but turns out not at all. The Airaid one is just thicker. Figured I'd heat wrap this to give it a chance to have some sort of heat absorbing resistance given its aluminum and has no heat shield near the filter. Perhaps I'll mock one up? We'll see how things go and if it stays in one piece.
I like the blue accents under the hood. I thought about doing my intake in blue silicone tubing, but thought it might look odd without modding other stuff to match, so went with black. Kinda sorta regretting that now that I see yours.
I love seeing accents under the hood, sets things apart [emoji14]
I say you should go back to that idea man, that'd be awesome
The intake tube looks like a mad science project with all the blue tubes. I like it alot. [emoji106]
littleblazer said:
The intake tube looks like a mad science project with all the tubes. I like it alot. [emoji106]
[emoji29] does it look bad? I am gonna trim more of the tubes shorter, they came long as hell
No it looks awesome. If you wanna trim do it but I think it's fine. Tell the haters it add more ponies. [emoji6]
I'm sure people would like how it looks, I love the way that heat wrap looks. Unfortunately the filter doesn't line up where I would of wanted, its not directly behind the gap in the middle of the headlight & cut out in the SS bumper
You're talking about the mesh opening on the cross bar on the grill correct?
Yes, although mine doesn't have mesh on it
Well the cross hatched portion. [emoji13] I've never seen an ss up close so I couldn't really tell you if that'll actually make a significant difference or not. I've heard it sounds better without the black box though so either way it's a plus right? Maybe rotate the pipe to get it closer to the opening?
There's no room to add any type of elbow or anything to route it, filter just fits where it sits. No room
Talk BT into getting a pipe bender and build a custom one. [emoji6]
Well we still want to do our ram air project one day
Reactions: littleblazer
22 Aug 2015:
Happened to spot the speakers I used for the front doors back in stock, so I plopped those in the rear doors and then put those SS panels on. All my SS panels are missing interior door handle bezels as they all broke a long time ago from constant removal. Will order those eventually, obviously haven't been in a rush to get around to that.
uploadfromtaptalk1440287967700.jpguploadfromtaptalk1440287991115.jpguploadfromtaptalk1440288009683.jpg
Thought of maybe trying out white as a new accent color on my rig, thoughts? Now I know people don't recommend that and seldom paint their calipers white, but I spend a lot of time cleaning my wheels and calipers anyway, even use a toothbrush. I feel it'd look interesting. Do the bowtie white as well?
I think white would look nice. If you go with all black rims you can also go with yellow and make it a true bat mobile. :twocents:
Only 2 full black wheels I like:
SS wheels (flat or gloss) and Verde Invictus
I would absolutely love to do yellow calipers, but nobody in the world has made super yellow colored LED strips that I can use to replace all the green strips I have on the outside. I would want everything to match if I did that. Its rather saddening I know I wouldn't be able to match everything color wise. Then I could really have a true batman color scheme going on
Reactions: Sib
Bro white calipers are a bad idea. So dirty all the time.
I'm bored of the blue, they darkened a tad over time. Time for something new. If not white then what do you suggest?
How about the old school Chevy orange? Might look good with the black?
You guys already make fun of me for having the "rainbow colors"
Nah, don't like honestly. What about green? Some sort of green? You suggested that before, but it needs to be as close as typical LED green as possible
Looks dark
Damn this is a tough decision. I'm tired of having too many colors going on. At least my grill and wheel wells match with green LEDs. Blue LEDs in domes, resoldering the light switch and rear wiper control blue instead if having the UV color. Door modules green still
cobalt60
