Can a 02 Envoy 4x4 be towed on a car dolly?
offduty
4
Looking to tow my 02 Envoy SLE 4x4 behind my motorhome. My Envoy has a Snoway plow setup so I can't put on a towbar without removing the plow frame. I want to tow it behind the motorhome using a car dolly. The manual says it can be flat towed with the transfer case in neutral and trans in park and goes on to say it is not designed to be dolly towed. Does anyone know why GMC says the Envoy is not designed to be dolly towed? With the transfer case in neutral would the rear axle roll fine with the front wheels strapped to a dolly or would the front whels also have to be able to roll? Has anyone dolly towed an Envoy/TB with the transfer case in neutral?
Welcome!
I'm sure the neutral TC mode will let the wheels roll just fine for short distances. The issue is possibly that the relative speed of the front driveshaft (zero) and the rear driveshaft (road speed) now appears across the transfer case clutches. Even though the clutches are not engaged, the relative motion is going to churn up the fluid, heating it up, and any residual friction between the clutch plates can damage them. Of course, thinking more, this is the identical situation if the front wheels are on the ground, unless neutral mode also engages the front axle actuator and then the front driveshaft is turning in the otherwise neutral mode and the only thing disconnected is the transmission.
A bit of experimentation would show if the front driveshaft is turning while rolling in TC neutral mode. Sorry I'm not with my shop manuals to see if they discuss the issue.
I think removing the rear driveshaft, or fabricating a tow bar adapter for your plow mount, are your only two options.
Also, does your tow dolly have electric brakes controlled by the MH? If not, that's a problem for many jurisdictions that limit the weight of unbraked towed things to 1500 or 2000 pounds. Perhaps your MH has brakes up for the task, but without self-powered electric brakes in the toad or the dolly, you won't have breakaway protection. That's a scary prospect.
offduty
4
Roadie, Thanks for the reply.
The dollies I'm looking at all have surge brakes w/breakaway but from what you say about how the TC works with clutches it sounds like dolly towing an Envoy is out. Bummer.
If the front driveshaft is turning with the TC in neutral would there be a chance the front axle would/could engage?
I like the idea of using a dolly since it could be used to tow different vehicles without having to have numerous tow bar mounts and braking systems installed. Guess I'll have to shop for a cheap front wheel drive car to toss on the dolly.
I forgot about surge breaks. Mrs. Roadie and I originally planned to cash in our house about now, retire, and run a MH around the country like everybody wanted to do in the 80's. I did a lot of planning, only to have her declare her annoyance with driving around, and then she found a partner and opened a brick and mortar quilting shop she has no exit strategy for and which ended up (darn) being profitable. So we're stuck.
What happens with the front driveshaft in neutral is an interesting question I'll have to research and do the experiment.
A cheap FWD toad is a better idea weight-wise anyway. My vision was to flat-tow a Jeep or Samurai, to preserve some offroading ability while forest camping with the MH.
I can't imagine there really being much difference flat towing vs front wheels on a dolly when the transfer case is in neutral. The front disconnect is not engaged in either case, so the front driveshaft and rear will be at different speeds regardless. Sure a few things will spin, but inside the case F and R shafts are not connected and all clutches are released, so it won't make any difference. The fluid may get a little warmed up from it, but no worse than the differentials (probably less even).
I think we may just be over analyzing it for no real reason.
I thought that was for the 2WD models. I should go back and read that again.
offduty
4
The_Roadie said:
The warning in the Owner's Manual is the thing giving us worry. If there wasn't some other technical reason, why would they forbid dolly towing?
Could the warning that the Envoy is not designed to be dolly towed be due to there being no steering lock?
I found these replies on the Woodall's site about if the steering needs to be locked when dolly towing:
"When on a dolly, the steering wheel MUST be locked, otherwise the dolly's swivel plate can turn 1 direction and the car's front wheels turn the other direction and you are pulling the car off center, possibly into the next lane."
"This is the reply I received from Forest River for their Car-Tow Dolly.
Quote: Always load the vehicle -in-tow facing forward. Making sure the steering wheel is immobilized by locking ignition switch or tying off steering wheel to seat frame or suitable point.. Towing a rearward-facing vehicle may cause swaying with towed combination."
Since the Envoy has no steering wheel lock maybe the lawyers at GMC decided to just blanket state "Not designed to be dolly towed" to cover GMC's butt.
As for pulling the weight my MH seems to handle it just fine. I towed a 20' trailer loaded with motorcycles (using a trailer toad to carry the tongue weight) back and forth from NY to FL (twice), VA, and SD and she performed flawlessly. Loaded the trailer (and toad) was about 6500 lbs. Tongue weight on the trailer toad a little over 1000 lbs., tongue weight carried by the MH less than 75 lbs. Only drawback was not really being able to back up with the trailer toad and trailer connected.
Good point on the steering lock. For flat towing no lock is a good thing.
linneje
404
When my starter went, the tow truck operator told me the dolly tow was OK, but he had to lock the steering wheel. He seemed pretty knowledgeable about the Envoy, knew the differences between the 4.2 and 5.3, and knew where the starter was located without even looking. So I trusted his knowledge. He assured me the tow was OK as long as he properly locked the steering.
KNBlazer said:
can't you just remove the driveshaft? tie up steering wheel and be done with it....
If you pull the driveshaft from the transfer case you'll empty it out all over the ground and have to refill it.
Reactions: KNBlazer
Well, my transfer case tail shaft seal leaks case fluid around the slip yoke (seal has been replaced, the yoke has some pitting from rust), so I figured if I pull the shaft completely out it would just empty all over.
Hatchet
2,405
Nope. That is what we did on my truck when we towed it for the engine swap. Tied up steering wheel, removed drive shaft.
offduty
4
Sure and if I was only going to dolly tow it one time I might consider that. I want to be able to bring it along on a regular basis and constantly removing and reinstalling the driveshaft is not something I want to be doing every time I go RV'ing.
loondog33
84
When I worked at uhaul 12 years ago, they had a style of car dolly that was a flat bed trailer so car is completely off the ground. I can't remember the trailer weight or load capacity, but with truck and trailer you would be in the 7300 lbs range.
fhendsbee
