I hope this is the right place for this.
I have searched far and wide, but to no avail.
I'm getting a C0244 code, no other codes as far as I can tell. No lights on the dash, stabilitrak, abs seem to work fine.
For the most part the truck drives fine. I do have a looseness/backlash/ slop issue in the drivetrain somewhere. Maybe related, I don't know.
It also has a somewhat hard 1st to 2nd shift, sometimes hard into 3rd aswell. It doesn't always shift hard, but most of the time.
Any ideas what it is?
Trailblazer service/history
>Bought it back in may 2015 with both stabilitrak lights on. It had about 124,000 miles on it. Seems to drive fine
>A couple weeks later I noticed the drivetrain issue. Doesn't seem to have worsened any.
>Scanned it with a bluetooth OBDII & dashcommand. Came up with co244 & c0455.
Replace steering wheel sensor, no more C0455 code or lights. Stabilitrak & abs functions fine.
>changed transmission fluid/filter(complete exchange) using dexron 6 aswell as transfer case(autotrak2). Just a tiny amount of metal particles in transmission pan.told it was normal.
>changed rear differential fluid.
I am aware of the shift kit fix for the 1-2 bump and new accumulaters. Maybe later. Right now I just don't know if this truck is worth it.
I am curious on what the cause of the C0244 code is and how to fix it.
