- Dec 5, 2011
- 109
I have searched all the threads in relation to the blend door operation and don't see anything that points to what I have happening. The air flow on the passenger side is higher than it is on the drivers side no matter the fan speed. The actuators are moving the doors from the dash to floor to defrost, you can put the AC on reciculate and the system will see that also. Is this a problem with the actuator or is it the drivers side temp sensor?
